bustitup
11.24.2008, 08:27 PM
You're right, the bottom plate should prevent that issue pretty much- I think Hoov discovered it just leaves a little light smoke damage around the edges of the plate; some unfortunate member of the idiot forum wasnt so lucky and suffered some damage to his lipos as his esc was stuck to the chassis directly...
Not to mention the hole it can burn through your lid if you don't get to it fast enough........mounting a esc stationary like that is kind of like not owning a fire extinguisher in your house because you don't think you will ever have a fire
JThiessen
JThiessen's Avatar
11.24.2008, 11:31 PM
I dont really see this as being an issue. If you do have a fire, by the time you get the body off, AND find a pair of gloves, its all toast already. What part of the ESC are you going to reach those soft little pink digits into and grab to get it off??? I've made the mistake of grabbing something burning ONCE....not going to do it again....I hope....!
longbill76
11.25.2008, 01:01 AM
Nice looking mount Brett, but I would like it to be a quick release, but that's me.
The o-rings I use are industrial strength, can take heat up to 500deg..if it ever does fail it will be a 50cent replacement.. I'm currently working on my HB D8 buggy so no time for the revo..but I did design a new MMM mount, similar concept but refined..
Carraig042
11.25.2008, 10:30 AM
Yeah, I am sure that the O-ring is strong, just I myself do not trust it. It is like a paranoid kind of thing I guess. I do like your design though and thought about something on those lines, but ended up coming up with a complete new design.
-Brett
Update.
Carraig042
Update. - 12.10.2008, 06:47 PM
Thought I would post an update. The battery wire configuration will more then likely change to clean it up a bit, but will work for the time being. I can not do any set-up of the MMM on my computer yet because the castle link CD was missing. The customer service was great and I should have it in a day or two. It was fine anyway as it will be a day or two for the batteries as well.
This system as a whole looks great! The motor is big and a great color of green, even though it does not match anything else on the truck. I can't wait until I get this thing running!
-Brett
