Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
ssspconcepts
ssspconcepts's Avatar
12.14.2008, 08:01 PM
Originally Posted by dangerwr View Post
Nice. I will probably go with the Novak conversion kit but I really like the idea using the RCPD top diff plate. Puts the ESC out of the way and makes room for battery tray. I can not wait to do my build. I was thinking of using Novak's HV 4.5 but believe that motor is 5000Kv and may get a little hot in the old parking lot. I was hoping for a +60mph car .
5S with a 2200kv Neu can easily be geared for 60+ mph...especially with this rig because it is very light and it will be a road car.
The EL8 RCPD top plate is nice but I recommend you get the one for the Jammin because I had to drill out the mounting holes quite a bit before everything would line up perfectly. I finished the mount by using some flanged spacers/washers so it would look nice and tidy.
dangerwr
12.14.2008, 09:09 PM
Gotcha. I will pick up the top plate for the Jammin' buggy. How light is the car compared to a 1/8th buggy? Also, it seems that you knew to upgrade the diffs--will the stock ones not hold up very long under BL?
ssspconcepts
12.14.2008, 10:01 PM
The stock diffs were plenty robust...I had a spare set of the spiders. I figured I'd use the spiders since I had them handy and they are smoother than the stockers. Not exactly sure, but the car is probably 10-15% lighter than the Jammin buggy-IMO. It is considerably lighter than my BL Jammin CRT, which is set up with the same conversion stuff.
dangerwr
12.14.2008, 11:21 PM
Are these the Spiders you are using?
http://www.amainhobbies.com/product_...ducts_id/24323
http://www.amainhobbies.com/product_...ducts_id/24324
Not exactly cheap! I think I can find them on eBay for a bit less. Not sure but will probably run the stock ones in the F/R but replace the center diff with a Spider. You mentioned there was a fit issue or is it a direct fit?
ssspconcepts
12.14.2008, 11:56 PM
Those are the ones. If you drop in a center diff, you will have to replace your rear center drive shaft with a different size...I have a spare if you need it.
dangerwr
12.15.2008, 12:19 AM
Thanks! I will let you know once I actually get down to it. I am wondering about that solid center shaft that another member posted the link on Tower or the Spider center diff. Is there an advantage to using a true differential over a solid shaft?
ssspconcepts
12.15.2008, 02:38 AM
I don't know yet...
My preference is to use either center diffs or trannies with a slipper. Mike's slipperential...when it is released...will do both!
To answer your question...you can simply install the collar that comes with that center solid shaft on the DM-1 stock 2-speed. It should work fine....when you get to that point there are plenty of members here that can help.
12.16.2008, 01:13 AM
...I am wondering about that solid center shaft that another member posted the link on Tower or the Spider center diff. Is there an advantage to using a true differential over a solid shaft?
I personally like the solid shaft. A center diff unloads too much and spins the front tires unnecessarily and you lose power. Unless you put really thick oil, and then where is the benefit? Maybe on a track where cornering is vital, but these have so much power that it's easy to drift around the corner if you want to turn tight.
I don't know what benefit a torsen diff (if that's what you mean by "spider") would offer. I can see using it in the front or rear to keep one side from unloading on corners. But the combination of stiff suspension and sway bars helps that a lot. Otherwise, it kinda acts like a solid shaft if used in the center...
