Jeremy1976
03.13.2009, 12:20 PM
Originally Posted by skellyo View Post
I actually recommend the 32P instead of the Mod1 for the Slash. It's much easier to find various sizes of 32P spurs for it to help with gearing choices. With such a small Mod1 spur, each jump in pinion tooth is quite a lot of change in speed.
I could not find any 32 pitch in 25t. Can the bore reducer that Mike has be used on any 5mm pinion such as the 32 pitch 5mm, or just the mod1? And can the 32 pitch be used with the stock Slash spur?
