stum
05.26.2009, 10:32 PM
i've been racing weekly a medusa v2 60mm 2000kv for nearly a year and only had to replace the bearings in my tekno 8ight-e. Wicked awesome motor and a very nimble weight to boot. MMM v3 for the esc.... save the money iMO, those castle 2200's are 140ish, these medusa's are only 110 and w/ a mmm they are both deadly and rock solid.
sabongi
06.29.2009, 01:04 PM
Any updates on the tekin motor?
Shark413
Shark413's Avatar
06.29.2009, 03:11 PM
Hi, regarding the Tekin motor. I am running them in my buggy and truggy. The buggy separated a magnet on the first pack, Tekin customer support got me a replacement within the week and it has about 6 packs thru it with no issues. The truggy motor has been going strong since day one (about 12 packs). Both motors perform well, are very strong, and temps are good. The 3mm/4mm mounting holes are a great feature (I use the Losi mount with 4mm screws). I have been running them with a MMM ESC and this combo works fine.
Separated magnet
New replacement rotor
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
Shark413
Shark413's Avatar
07.02.2009, 03:57 PM
Update:
It was really hot out here in Socal at the end of June, but the track is going to be closed for a few weeks so I wanted to get one last weekend of practice to stress test the Tekin motor (and new rotor). It may not get as hot as some places but the the air temp was 106 degrees and the track surface was 135 degrees, so this was a good test on how the battery, ESC and motor would handle the heat. I put three 4s Neuenergy packs thru, I dropped down a tooth on the pinion because of the heat (47/14T). Max temps on the motor were in the low 180's and the Battery hit 110. Performance was great the weather was not.
Shark413
Shark413's Avatar
07.28.2009, 04:41 PM
Been a while so I thought I would pass on some updated info. Still super hot at the local track recently, air temps 106+ and ground temps 140 degrees. So I got some extended run time in during the day to see how the electronics would hold up. The Tekin T8 and MMM motors held up great and temps were decent (never got hotter than 175 degrees). My MMM ESC handled the heat fine, but I did have a problem with the fan, it was working intermittently. I always check to see if it is working when I first turn on the ESC and the fan was not moving. I removed the fan and tested it and it was indeed dead. I have several MMM ESC's and this is about the 3rd fan failure. It is a pain to remove the ESC, take the case apart and remove the fan, so I decided to make it a little easier. I don't recommend you do this because it could void your warranty, but I bascially attached the fan to the outside of the case and ran the wires directly to my rx so the fan was on all the time. This setup allows quick replacement of a broken fan, you can tell right away if the fan is dead and it runs all the time, which keeps the ESC cooler. Just drilled two holes and used two 3mm screws to hold the fan down.
emaxxnitro
emaxxnitro's Avatar
07.28.2009, 08:30 PM
warranty void lol!
808E
