big greg
07.06.2009, 09:01 PM
4s is more than necessary.
5s, maybe for a big track with higher speeds and longer straights.
Turning down the EPA is non-sense. Set the car up right. Turning down the EPA is limit the ESC and thus making it always have to work hard to know the motor timing and when to send power. Where as, when you have the ability, the ESc is now capable of working less, or "thinking" less and should therefore run cooler.
turning the epa down is nonsense huh? have you not read my post? all it is doing is limiting your motor speed when running higher voltages, my speedo ran no hotter when i turned it down from 125 to 90, shoot im gonna buy a 6s and leave my gearing the same with the epa at about 70, just to do it
starscream
RC-Monster TQ
starscream's Avatar
07.06.2009, 10:58 PM
I don't believe it's nonsense as partial throttle is hard on the ESC. There are reasons why they make different types of ESC's for cars, boats, planes/heli's.
You would be better off gearing down but the EPA is an option, just not the best option.
Higher voltage is always more efficient but you need to have the appropriate wind motor and gearing.
A 5S 4000mAh pack is equivalent to a 4S 5000mAh but the 5S system will run cooler with the appropriate setup
A 6S 3200mAh pack is equivalent to a 4S 5000mAh but the 6S system will run even cooler with the appropriate setup
Ha Ha
Mentat
Brushless Mentat
Mentat's Avatar
07.06.2009, 11:17 PM
I do not believe this is true.
FS: 8ight-t Race Roller TONS of UPGRADES
8ight 1.0 & 2.0 | 8ight-T 1.0 & 2.0 | E-Revo BL Edition | T-Maxx | Slash | Raze-ST | XXX-NT Drake | 3PKS | DX3S Telemetry
starscream
RC-Monster TQ
starscream's Avatar
07.07.2009, 12:07 AM
Thats OK, you don't have to believe me, just do the math
Granted 6S would actually = 3333.33mAh, but with the extra efficiency, 3200mAh will suffice.
Ha Ha
Mentat
Brushless Mentat
Mentat's Avatar
07.07.2009, 12:51 AM
thats more like it. i was merely saying that the value he was giving isnt correct.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.07.2009, 01:12 AM
Ah, okay gotcha... he is right as well, you need less "total" energy when you increase pack voltage. Higher C batteries will also give more energy than a lower C batt, simply because the voltage is higher under load, less throttle pull = less mah pull from battery.
zeropointbug
Z-Pinch racer
07.07.2009, 12:39 AM
Are you joking?
