Well, it's a very complex and time consuming procedure, where you take any load off the motor and run the thing WOT and measure the currents using an eagletree or similar unit. Now, this is only for the non faint of heart and experienced RCist.
Well I didn't know, I didn't think you were supposed to run them at full throttle without a load (though I have done it), and idle to me means low rpm.
Jeff
Jeff
free load actually. There is nothing wrong with testing motors without a load.
Jeff
j/k about that... well about it being complex and all. It's just the no load full rpm is what idle current would be. For instance, my 1512/3D on 6s lipo will consume only 1.5amps at 40,000rpm with no load.
I forget you guys run all those low Kv motors, my lowest is 3.3Kv and they go up from there so my last 3 are well over 60K at 3S
Jeff
