loa
08.24.2009, 07:15 PM
IF your running 2 packs;
Not to pull $ out from under Mike but I'd consider 2-3000mah or 2-4000mah
5s packs and Castle 2200 ?
Why not two 5000mAh?
And a nice 5S pack with the ccneu motor would be too expensive for me...
And you can get a Tekin motor or a ccneu for under 175-
Well add tx and shipping (and probably duties since I'm in Canada) and you quickly get to 200$... :-)
Loa
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.24.2009, 07:29 PM
Well, I was suggesting the smaller Mah packs because they are cheaper and still don't know if your have a single or dual battery setup ?
2-5s 3000mah would be 6000mah wired is paraellel.You should yeild a 30-40 minute runtime
The 5000mah in twins would weigh a ton.
08.24.2009, 07:34 PM
Loa
First, I did not notice you were form Canada so you are correct on the $200-.
If you are running 2 batts. in parallel, you could get, as mentioned above, 2 5s 3000 mah for a 5s 6k set up. One advantage is that the lower mah. batts. are cheaper than say a 5k batt.
