crazyjr
crazyjr's Avatar
08.30.2009, 07:41 PM
Originally Posted by starscream View Post
I agree that the Novak HV system is smooth and I had some success with it in my buggy but unfortunately the system is not engineered properly and will eventually fail. I'm not sure how Novak keeps up with all the warranties for these esc's. I'm also puzzled why the HV's seem to work OK in MT's and fail so often in a buggy.
I think it's direct drive verses a gearbox/slipper setups, only thing i can think of. May also be the body is higher and allows more air to cool, Buggies don't have much room for air vents
emaxxnitro
emaxxnitro's Avatar
08.30.2009, 07:50 PM
tranny vs. direct drive?
808E
starscream
RC-Monster TQ
starscream's Avatar
08.30.2009, 07:56 PM
The revo's slipper clutch can help reduce the amount of initial current.
Unless you run RCM's slipper diff, then its possible that the buggies direct drive may pull more current than a MT.
The MT's may also soak up bumps better than a buggy which may keep the fans from failing as easily.
The HV needs proper cooling or it will "let the smoke out"
Ha Ha
emaxxnitro
emaxxnitro's Avatar
08.31.2009, 12:19 PM
thats it! the center diff, it unloads pulls more current. thats why hv's fail with buggys. your good...
808E
starscream
RC-Monster TQ
starscream's Avatar
08.30.2009, 07:51 PM
Sorry for side tracking the thread...
I think you're right. If the fan looses teeth or fails at all the HV will go up in smoke. If any esc requires a fan from "letting the smoke out" then a built-in thermal shutdown should be required as well. Whats funny is that the HV motor has this feature but not the ESC...
I'm interested to see Novaks 8th scale ESC though. I haven't heard anything about it lately though
Ha Ha
