yeh mate ,I've had mine on 5s for a long while and have mates also running 5s with the MM esc ,just uprade the wires to 12g wet noodle,should be sweet then.
If you're using motor brakes 5s is the highest I'd go due to voltage spikes. I'd also add some extra caps to be safe and a fan. If you run mechanical brakes, 6s will work on the MM with just a fan. An external BEC is a must of course on both.
I've try 6s on a MM ,it doesn't except the voltage.......wan't start up
