Matthew_Armeni
Matthew_Armeni's Avatar
11.08.2009, 04:07 AM
If you're using motor brakes 5s is the highest I'd go due to voltage spikes. I'd also add some extra caps to be safe and a fan. If you run mechanical brakes, 6s will work on the MM with just a fan. An external BEC is a must of course on both.
  Send a message via AIM to Matthew_Armeni
