maneba
11.06.2010, 08:42 AM
Originally Posted by tashpop View Post
wow, you have almost completly did my exact conversion i just completed. you have better machine work on the mounts than i do, but very close setup. we think exactly alike on how this should be setup. bravo to us both. i will post some picks of mine later.
did you cut down your front shaft? mine is alot tighter than yours is.
Yes, i think about 1 cm. I would like to split the 6S and put two 3s lipo aside the rear shaft. In a lower position for a better CG.
tashpop
11.06.2010, 09:12 AM
so funny, i was also thinking the exact same. i put the motor plate back in for now just to hold my current 3s in since its too long to fit that spot.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
