maneba
11.06.2010, 08:42 AM
Originally Posted by tashpop View Post
wow, you have almost completly did my exact conversion i just completed. you have better machine work on the mounts than i do, but very close setup. we think exactly alike on how this should be setup. bravo to us both. i will post some picks of mine later.
did you cut down your front shaft? mine is alot tighter than yours is.
Yes, i think about 1 cm. I would like to split the 6S and put two 3s lipo aside the rear shaft. In a lower position for a better CG.
