bigsteel
03.03.2011, 09:51 AM
I really need to pick up an extractor set,with how many rounded out allens my 5B has I'm bound to need one soon
Josh did you find that elusive spot with your tool? Gee!
After about 20 mins of mindlessly fumbling around I managed to get it
pinkpanda3310
pinkpanda3310's Avatar
03.03.2011, 07:31 PM
Originally Posted by vader2728 View Post
Patience. My best "tool"...
I exercise patience but it's more of a 'have to' wait for parts.
Originally Posted by TexasSP View Post
The little traxxas T wrench that comes in there RTR's is one of my favorites. I use it quite often on all my vehicles.
Me three
I also always have a chunk of 2x4 laying around, I have a couple holes drilled in it for holding bullets upright while soldering, I do all my soldering on or over it to prevent burning my work bench. It also doubles as a car stand for my carpet car, it has been very useful many times in many different ways.
I use a saw stool too.
Too beefy, huh...
I think he's referring to previous activities. Must smell like $h1t.
You could use the dremel to cut slots in the screw head and use a flat head screwdriver if you think it's going to strip.
It took you 20mins!? I would have lost interest by then.
If I'm doing a lot of cutting with the dremel I will often use a 4" grinder to do the bulk of the work. Along with that - a file and sandpaper. Tappers for threading and rethreading holes. Calipers.
bigsteel
03.03.2011, 07:56 PM
Nah,it took a double dose but linc was good and passed out. He should check for pills in the next pie I make him.
florianz
03.08.2011, 06:12 AM
double sided sticky tape, the heavy duty stuff. I've mounted rx, esc with it. the esc is right on the chassis, for a low cog. never caused any problems.
these screw removers are great, surprisingly it works:
http://www.conrad.de/ce/de/product/8...AUSDREHER-SATZ
a small gas lighter to get screws removed, which are secured with loctite
http://www.conrad.de/ce/de/product/8...archDetail=005
gripping pliers are always good to have.
Useful tools
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Useful tools - 03.08.2011, 12:25 PM
VELCRO is a must have.
I also use a small propane torch for doing hot work like shrinkwrap stuff.
A small drill press is also a nice tool to have around the shop.
SUPERMAXX YOUR LIFE.
