TroubleMan
05.15.2011, 04:43 PM
this was some rush work when i first built the cars but now i have cnc mill access the motor mount will be replaced this week for the up and coming season. the other car is a XR80 he's now running 8s with mech brake . i have a small crack from a collision that happend last year in my front bulk so... since i don't have my bearings done yet i could post the process i use here.
Name:	2011-05-15 16.25.32_Detroit_Michigan_US.jpg
ID:	9948   Click image for larger version
Name:	2011-05-15 16.26.04_Detroit_Michigan_US.jpg
ID:	9949   Click image for larger version
Name:	2011-05-15 16.26.19_Detroit_Michigan_US.jpg
TroubleMan
05.15.2011, 04:56 PM
Also on the brakes im not really sure how other people feel about the current setup for these cars, i watched a few races with these puppy's and it seems they use the brakes to help rotate the car in the corners and i have no need for this feature so i locked the fronts to help control braking from higher speeds. so it may not be for everyone but it sure tames the car to be driven like a normal car. just my few marbles
05.15.2011, 06:32 PM
Ok then...how did you accomplish this. With my mrx-4, if I tap the bakes just a little to much, I am in trouble
TroubleMan
05.15.2011, 11:31 PM
The bearing size is 10x6x12mm for these cars i looked for a while for a bushing this size with no luck and then i was forced to make them but now i have options so tomorrow ill have some bushings made. I will be thread locking the bushings then drilling then tapping and ending with a grub to lock the wheels.
Name:	2011-05-15 19.02.33.jpg
ID:	9954   Click image for larger version
Name:	2011-05-15 19.02.01.jpg
ID:	9955   Click image for larger version
Name:	2011-05-15 18.46.12_Detroit_Michigan_US.jpg
superek4
superek4's Avatar
05.21.2011, 06:02 AM
What bearings are these?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
BIG-block
05.22.2011, 02:42 AM
Is one of those motors in the last pic much fatter than the other or is it just my eyes playing tricks on me?????
You ask and you shall receive...Although it's a MRX-3...same basic set up. It's a Revo motor mount
I had a machinist press a fitting inside the hub which in turn eliminated the one way bearing and allows me reverse and motor bakes. Eventually I am going to eliminate the AL bottom battery brace and replace it with carbon fiber...
I am running a 1800kv on 6s and it flies...haven't quite dialed in the esc for a little drag brake, motor brakes yet but working on it. The first time I took it out I almost totaled the car..missed a concrete light stanchion by inches doing 50mph+ This is my first true on road car as it has a learning curve as I only have been running in the dirt
Thanks for that pics guys. This is going to help immensely with my Serpent 960 conversion I think I am going to do the batteries the same way as you did magman. I hope I can get some 4-5mm thick carbon fiber plate and make like a wide pan chassis so that the batteries can fit on the sides of the chassis. I think that would be the neatest and easiest solution (posibly the lightest as well). Do you guys think that 5mm thick carbon fiber would be ok for the main chassis (bare in mind it will be a lot wider and hold the lipos on the sides)???? Once again thanks the pictures. Great help.
Overdriven
Destroyer of Tires
Overdriven's Avatar
05.22.2011, 11:01 PM
Magman is running a CC1512 1800kv. The shorter can size in a small space does play tricks on your eyes a bit.
BIG-block
05.23.2011, 05:11 AM
OK, that's what I was thinking. The next motor in size up (diameter wise) is the 1717 and that would be just plain crazy in one of these things.
x-y
x-y's Avatar
05.16.2011, 05:49 AM
I recommend you protect the lipos with a aluminum plate or a hard plastic ....... if you have a bad crash is possible have a disaster :p
http://www.youtube.com/watch?v=awOIy...layer_embedded
SWORKZ BE-1, LEOPARD, HOBBYWING, GENS ACE, SANWA VX, FUTABA 3PL, MBX5R/T, RB5SPSL, FG MONSTER, TC5R, 808E, HYPER8, TF5, ZX5, NANO-TECH, HYPERION, 620DMG, ECO6-10, TEAM-IHOBBIES
TroubleMan
05.16.2011, 12:21 PM
With this kind of car it's like riding a motorcycle it's risky,dangerous, but i fully understand what i'm doin and i wish lipo were not so dangerous but no pain no gain !
