zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.17.2007, 12:58 AM
Originally Posted by AAngel
I think that the 3.5mm plugs would be too small. I don't think that they are rated for much current at all.
The wires on the Feigaos that I've seen have the last half inch or so bare and tinned so that you can solder to them. The rest of the motor wires appear to have some sort of varnish on them, which (from what I understand) resist soldering.
Oh really, I probably wouldn't be able to strip the enamel off the wire either... and any longer than a couple cm is pointless to do this. So, maybe just scrap that idea... :007:
Was your chassis alum.? How would 500F make it more pliable?
