neweuser
neweuser's Avatar
04.24.2007, 09:00 AM
Cajun, yes, you are going to need a ubec OR an RX pack. To disable the BEC in the MM just pull the little tab on the connector upward that goes into the RX and remove the red wire. I pulled mine and heat shrinked it back so if I ever need it (not likely) I can. Pretty simple.
Cajun
04.24.2007, 09:56 AM
So you take the lead from the ESC that goes into the throttle slot on the RX and diconnect the red (power) wire and plug it back into the RX, then add the UBEC in you power loop from your bateries and plug it into the slot on the RX labeled batt, right?
Will I need a capacitor in the system?
