Race Run Times?
AAngel
04.25.2007, 11:05 PM
What setup are you running? The problem I was having was the Feigao motors I was using would heat up too much. If you're running a sane setup, an 8Ah pack should do you. GD is running a 12Ah setup and he's having no troubles.
AAngel
