Patrick
Patrick's Avatar
05.04.2007, 10:46 PM
Originally Posted by SixShooter
This to me would be your best bullet proof route in my opinion but I would try ditching the spools first since I'm kinda cheap lol I personaly run 5k in both diffs ( basher only) and it works fine. I get some slippage but the truck is more controllable now instead of with the spool. I'm pretty sure they make some thicker stuff like 10k if you need a little less slippage.
You can get much thicker oil than 10k, the thickest I've heard of is 300k.
Alloy diff cases (external and internal) have worked well for me so far, with a 7xl. But if your willing to spend the money, then FLM hybrids and some 1/8th diffs eg HB should be strong enough to not really need to worry about.
What motor are you using in it now?
If you change the rear diff to 1/8th you have to change the front as well since they are a different ratio to e-maxx diffs.
HB also has the Pro diffs which are a different ratio again. For an e-maxx I would use the standard ratio version, but since yours has such big wheels you might want the different ratio. Use BrianG's speed calculator to see what ratio would be best suited to your car if you decide to use 1/8th diffs.
SixShooter
05.05.2007, 03:41 AM
Cool, I may try some thicker lube one of these days.
1bigemaxx
05.09.2007, 10:04 AM
Thanks for thw input guys. I know I need to dedicate 1 of my vehicles for crawling and 1 for all-out bashing. For now I'm shelving the bigemaxx and will be driving the t-maxx for a while untill I decide.
