05.16.2007, 12:14 AM
Originally Posted by E-MAXX Rock's
...i want 45 ish give or take a lil bit.... when i type in what i THINK for the crt .5 or everything i get 46mph, but then i type my info into the motor chooser and it says its to kigh of kv, which may be over heating, but it worked fine with u go to speed, so idk, can u tell me what i need for this?...
And for those who may wonder the same thing: The speed calculator has a dropdown list for various motors. When you select one of these, the program also knows the recommended safe max rpm for that specific motor - when known. Example; Neu or LMT motors may have a higher max rpm than a Wanderer or Feigao motor. However, when you are using the "solver" page, and are trying to find the ideal motor KV for your setup, the program doesn't know which motor you are going to use, it just knows the KV needed. So it assumes the worst case and uses the generally agreed upon 35k rpm as the max rpm.
I hope that made sense.
