IBJAMMIN
IBJAMMIN's Avatar
05.16.2007, 10:42 PM
Yep I was thinking 6-8s with Castles 110hv.:005:
I just couldn't pass up the 1506 motor for 135 though It is almost the same size as the as the Mamba Max motor and a loaded 5500kv vers unloaded? some say MM 5700kv I need to get some good data in the eagletree with the Mamba and compare it the the Neu see if it is really worth it to spend the extra money on a high end motor? :032:
