05.24.2007, 09:41 AM
Originally Posted by aqwut
I had duals, and triple setups... I do like the single setup much better. Hey, if you want it to look symmetric, put ur ESC inside the can of an empy motor and mount it on the other side:005:
Interesting idea.
Then add to that idea......>>>>vent one end of the can and put a fan on the other end for a cross flow cooling arrangement. Interesting......
05.24.2007, 12:47 PM
Originally Posted by Serum
Gustav; One mm controller can take the maxximum power from a lipo pack, at a more efficient factor than a dual setup.
Dual is a nono for me. (as well as for other users) but if 0700 wants a dual setup, we need to advise him what we think is best.
Yeah,i know,dual is not something i'd do either, ideally, but i can see a case for it,sort of.It's hard to recommend a 6-8s controller at the moment,that's why.
You'd have to have some hot motor on 4s to keep up with a pair of milder systems on 4s,closes the efficiency gap a little if you're chasing a certain amount of power,at least it won't thermal.Also,using a pair of cheaper,lighter 4s packs,since you'd be taking less current from each,helps some with the cost and weight difference.So say you're taking 70% of the amps each,from a pair of 4s packs,that you'd be taking from a single,more powerful 4s pack with a single big motor and single esc,you'd still be up on power whilst being down on temperature and load on each esc..
So i'd take it over running a single mega hot motor,although it's not ideal,going higher voltage with a single system is.Me personally,i'm building everything light these days so i can run cool 4s setups (single),35mph is enough for me,i just want a cool running,hassle free setup that is nice to drive and has plenty of snap.the novelty of running huge power up and down in straight lines wears off,then you just want to get on with driving.until some alternative high voltage controllers come along,then i might build some big monsters again.
0700,do you have an idea what you want to spend? and if you want to make them useable as single systems in other applications?
05.24.2007, 12:53 PM
Originally Posted by Procharged5.0
Interesting idea.
I do actually like that idea- put a small ducted fan on one end of the empty can and turn it into a mini wind tunnel. That should keep the esc cool.:028:
05.25.2007, 02:03 PM
You guy have been great, you've definitely got me shopping for a single motor/controller combo....so far I'm looking at these...
neu/quark - $600?
novak 4.5 - $250?
MMM - $350 - not released
Traxxas - $? - not released
05.25.2007, 02:06 PM
Skip the Novak piece.
The MM/Feigao combo is good
The MM/Lehner combo is better
Quark NEU is very good
depends alot on your budget.
the Warrior 9920/Feigao 8XL/9XL offers great "bang for the buck"
05.25.2007, 02:31 PM
Should I wait on the TRX or MMM? I talked to the engineer at castle, he said they're aiming at neu/quark level, but at a lower mass market price?
And of course, now TRX wants to joust with them.
05.25.2007, 02:39 PM
Should you wait...........
Very good question. It will probably be several months (Minimum) to a year before either is available. How long can you wait?
Last year I was in the same position. I deceided not to wait and bought a MM with a NEU 1515 with the intention of moving the MM to another lighter truck and buying the MMM when it comes out. Well, I'm still waiting! LOL!
05.25.2007, 02:42 PM
I'd talk to the engineer again and ask for an approximate release date- give or take a few months- otherwise we'll all be grey & old by the time its released...
05.25.2007, 02:43 PM
:005: That's entirely possible!
05.25.2007, 03:17 PM
He said they JUST got their motor supplier issues worked out, they wanted neu, but he didn't have the capacity they needed. They're testing samples now and expect good news in July.
05.25.2007, 03:24 PM
The $560 neu/quark setup is temping, esp if I could find a deal....
05.29.2007, 11:16 AM
Who shared this new info with you????
05.29.2007, 12:22 PM
I'm with procharged.. Who.. ?
05.29.2007, 01:18 PM
Engineer guy who picked up the tech support line. Said the controller has been done for a very long time, the hold up has been a motor supplier who could meet the quality AND production numbers they needed to release the product en mass.
I was very impressed with their business attitude in general and I'm happy to wait a few months to get a product with so much thought behind it.
05.29.2007, 01:27 PM
I'm a Castle fan, but in all seriousness, I've heard this before.....almost one year ago! Then again at the iHobby show in October, then again at....
