Originally Posted by AAngel
I'm hoping that the Nue will be all that I need. The only reason that the Lehners are even a consideration for me is because they run well with the MM controller. If the MM/Neu issue were to be "fixed," I wouldn't care if the Lehner wasn't around at all any more.
You're not alone with that opinion. If only we had more choices on contollers to run those nice NEUs. I'm fed up with Quark at the moment...
