why is my quark getting so hot?
AAngel
06.26.2007, 07:37 PM
The Quarks run hot. All you can do is provide additional cooling for it. Most here attach some sort of heatsink to the case of the Quark and add fans.
When running a Revo, I'd say that 4S is the minimum battery configuration that you should go with.
Going with a lower kv motor will help with the current draw, but you will sacrifice performance.
AAngel
Hybrid Mode
Switch to Threaded Mode
