Cartwheels
06.27.2007, 04:48 PM
Originally Posted by GorillaMaxx360
i have a quick question for you guys. i have my maxx shelved (uncompleted) and when i get it running i want to fire it up on the first run so to say. I know this is hard but what do i have to do to my quark to allow it to run (dont care if it runs hot) without thermaling. i cant do the mod because i m not good with electonics and sodering. i will be using my maxx(look at avatar), a pretty heavy beast, ex ubec, 3330z servo, 14cells ib 4200s, 2200kv neu, and 40series tires. what heatsinks/fans should i use. thanks
I have done the mods to a couple of Quarks. I never did any soldering when I did them. It is not absolutely necessary. Once you remove the top and the battery side end you can run a small flat blade screwdriver under the caps to the aluminum spacer. Pry between the case and the aluminum spacer. Take it slow and becarefull not to pry on the electronic boards or caps, only the spacer. The whole insides will lift off at an angle till you can slide out the back end. There are some threads around that can help you with the rest.
You might want to try it before you mod it you may not need to mod it.
