FLM Bulkless (Run dry or oil em?)
Hernz
FLM Bulkless (Run dry or oil em?) - 08.28.2007, 01:21 AM
hey guys i picked up a set of FLM bulkless a while ago and its time to put em in. i recieved them without oil or grease.
do i run these dry or do i put diff oil in them?
any suggestions for wt? i'll just be bashing. i have titans but most likely getting the novak 4.5
Serum
Serum's Avatar
08.28.2007, 01:30 AM
The diffs (ringgear/pinion) are used with grease, the internal gears of the diffs are used with silicone oil.
Thread moved to FLM.
Hernz
08.28.2007, 02:40 AM
thanks for clarifying serum
DickyT
08.28.2007, 08:41 AM
I use White lithium grease on the ring/pinion gear and Ofna Green Stuff Differential grease for inside the diff cups.
http://www2.towerhobbies.com/cgi-bin...?&I=LXESC0&P=7
wallot
wallot's Avatar
08.28.2007, 08:47 AM
I use Protech Speed greese on pinion/bevel gears and oils inside.Oil can completely change handling of the truck. After trial/error i ended up with 7k in front and 10k in rear.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
Serum
Serum's Avatar
08.28.2007, 02:59 PM
That green stuff is a horror for (most) o-rings. with 1/8th diffs, you are better off using silicone inside the diffs.
