lutach
lutach's Avatar
08.31.2007, 04:25 PM
Just came back from running the truck with the MGM 16016-3S. The MGM is silky smooth. I only have to change the brake delay and the freewheel. It took a good second or so for the brakes to kick in. I ran a little over 5 minutes as well. The only thing I noticed is right where the power wires connect to the ESC, it ripped the shrink wrap. I also noticed that the motor got really hot. The batteries were just warm and so was the ESC. I put the batteries on the charger right now and it showed 11.41V. The data shows that the MGM was a little more efficient than the MM. Next I will try the Schulze future-18.97KWF.
Name:	Mr. C's MBX5T, MGM 16016-3S, 2600Kv motor, 2 2200mAh 11.1V (4400mAh).jpg
