squeeforever
squeeforever's Avatar
09.03.2007, 08:30 PM
Well the LS10 will be possible on that budget, but it'll be tight most likely. Personally, I go with the MM 4600 on 3S. If you spend your money wisely, you won't have a problem since you would be selling the nitro stuff. I would get a 3S 8000mah pack from TrueRC for it, and a MRC 989 charger and a LBA10 balancer. That should be within your budget. You might not have room for the 8000mah pack though.
So heres what I came up with-
$189 for the LS10
$213 for the MM 4600
$105 for the 3S2P 8000mah LiPo
$145 for the MRC 989
$50 for the LBA10
=$702 minus what you sell the motor, radio, etc. for + 30 or $40 for odds and ends. Not bad considering you will have a really good setup.
