09.14.2007, 12:59 AM
Is the Revo spur fit on the Stampede xl5 slipper???
I want to put my feigao 540 9L on my FLM stampede on 3s li-po, the shaft of my motor is 5mm and the only pinion i have is mod1.
The revo gear will fir but will be too small and require a tiny pinion. An Associated Monster GT spur will fit with slight modification and is mod 1, 52 teeth. This helps cause the largest revo spur is 40 tooth and will cause gearing issues, think 5-8 tooth pinion to get anywhere near correct for the rustler. To mod the MGT spur the center hole must be opened up to accept the bearing from the slipper. I also drill out three of the smaller holes to the same size as the mounting bosses on the slipper so that the spur will sit flush with the slipper. This may sound difficult but is really clear when you have the gear next to the slipper. Kimbrough makes different sized spurs for the MGT and that will help with gearing.
