09.18.2007, 10:33 AM
What ratio, sput/pinion, are you trying to achive. If you want to run a larger spur than 51 teeth you would need to run a larger pinion to get the same ratio. For example a 51/18 would have the same ratio as a 65/23, both about 2.83/1.
