ncalenda
Need for Speed
ncalenda's Avatar
09.27.2007, 01:49 PM
Right now I'm running 24/76 on sand, and I have a fan on the ESC. When I use 3S it will thermal at times, with 2S it is fine.
I was thinking that with a stronger setup that I could run this gearing with 3S and without a thermal issue. I guess that is not the case.
The XVL motor I think it using a small can, would a larger motor help? Or, would that cause the ESC to over heat quicker?
  Send a message via AIM to ncalenda
09.27.2007, 02:43 PM
Pesonally, I use the mm and a feigao 12s 3000kv motor on 3s in my pede. If you are doing 4wd, crt.5 or similar size/weight, a mm with a feigao 10l on 4s or a 9l/8l on 3s would be the ticket for a low cost good performing system. The mm controller may run the vxl motor too, should have similar performance to my 12s feigao. I run a 45/15 geaing which is similar to 23/83 gearing. I am guessing you have a rustler, that gearing would be too much in a pede with the larger tires.
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
09.27.2007, 05:36 PM
I have a Mamba Max system, and I really like the ESC. I was wondering if anyone has ever ran the VXL motor off the Mamba ESC. I'm thinking about doing it when I finally get my Rusty running good.
Brijar!!!
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
ncalenda
Need for Speed
ncalenda's Avatar
09.27.2007, 08:22 PM
Ya, I have the rustler. I was thinking if I should consider an upgrade, I have heard so much about the MM setup.
