Originally Posted by BrianG
If you do go with the Revo knuckles, I'd try the RPM ones, or an Al setup as the stockers are a little weak from what I've found. Some have no issues, but I was popping the pillow balls out of the stockers left and right until I got RPM.
I know the RPM ones use different bearings than stock, so you might want to check into that before you buy them.
Thanks what about the aluminum Traxxas Revo knuckles? I thought they made some?
