upgraded to VXL Tranny internals in FLM Rusto -
10.10.2007, 01:26 AM
I upgraded the tranny gears to all steel (VXL) and used Avid Revolution bearings. Did some nice smooth speed runs and its ready for Sunday's TNT Dragrace. It's a bit noisier then with the plastic diff in there. I packed the diff with Vaseline instead of grease this time. Going to see how it works out over time.
It's alot easier to find the old style spur gears around my area. And for dragracing I have less rotating mass on the spur, since I run it in the locked mode with this adapter.
Ok, makes sense. If you are not going to use the slipper, then there is no point having the extra weight.
