Holes in the body to reduce heat?
Hakan_J
Holes in the body to reduce heat? - 10.19.2007, 08:40 AM
Hi,
I have no holes in the body (keeps it very clean!), has anyone measued if there is a big difference between no holes and holes? I think my motor gets a little too hot and Im considering cutting a hole just above the motor.
If I could use a body without holes I would prefer that. Has anyone any experince with this?
Br,
Håkan J
mkrusedc
NeuMaxx
mkrusedc's Avatar
10.19.2007, 09:13 AM
Yes I posted them in another forum:
http://monster.traxxas.com/showthread.php?t=372806
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
10.19.2007, 09:15 AM
I've had more issues with the ESC getting hot, rather than the motor. I usually make a slot in the body to direct air right to the heatsink, and then I don't have any problems. With my ZX-5, I have the ESC mounted high, so I cut out the front window so cool air blasts right on the ESC. Running that 7700kv setup heats the ESC up pretty good, so that works good to solve that problem.
I'm not so sure how much that would help a motor, unless you have some sort of finned heatsink on it. Smooth cans don't offer much surface area to dissipate heat.
Finnster
KillaHurtz
Finnster's Avatar
10.19.2007, 09:31 AM
What exactly are your temps?
I tend to not like to cut holes in my body. Call it a perk of BL. I worry more about mud and water accidently splashing in on the electronics than some heat. I had a small fan on my MM esc that helped alot, otherwise I position the electronics near the rear wheelwell so it gets some airflow but in not really in the path of mud or water. Now I have a HV high efficiency setup that stays cool no matter what.
Ex: Earlier this week I was bashing @ a const lot. It was fairly dry, but there was a soupy muddy patch that I hit fairly fast. Mud flew and coated the body. Worried about the electronics, I opened the lid. The inside was completely clean. I flung what I could off the body and continued on.
Hakan_J
10.19.2007, 09:54 AM
I agree it IS nice with a body without holes, but if it would really help with my motor temps I would make some holes. My lehner gets to around 85 C (185 F) and some times even higher! I wouldnt mind having it run a little cooler!
I also have a fan on my mm, it helped alot!
Hakan_J
10.19.2007, 09:55 AM
Thanks for the link, alot of really good info in that thread!
mkrusedc
NeuMaxx
mkrusedc's Avatar
10.19.2007, 10:08 AM
You are welcome. Everybody was debating the merits of cooling modifications so I fiqured I would see for myself. Good luck.
Hakan_J
10.20.2007, 05:45 AM
I think this:
was really interesting.....anyone here tried that?
Edit:
The spacers i mean..
AE RC 8FT
KO Propo EX 10 Helios
Tekno NEU 1515 1Y
Mamba Monster
TrueRC 4s 8000 Mah
2FastSS4U
RCM Brushless Savage
2FastSS4U's Avatar
10.20.2007, 07:37 AM
I personally thought that with the motors touching the motor mount would help draw heat away from the front of the can. I may be wrong though.
The wisest mind has something yet to learn. (George Santayana)
