glassdoctor
TEAM FUSION
glassdoctor's Avatar
10.30.2007, 10:07 PM
Just use the meter on a DC setting.. check the main lead wires. If the packs have a tap plug, you can also check the voltage of each cell in the pack. Put the probes on two adjacent pins (careful to not let the probes touch) and it should show the volt of a cell... then move the probes over one spot and it will show the next cell. etc...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
