MetalMan
MetalMan's Avatar
11.05.2007, 03:17 PM
I always knew the slipper clutch shaft was hardly in the rear bearing, but I never had an issue with it falling out (from the set screw on the pinion loosening). As you can see, the reason for this is that the bulkhead pieces utilize the stock transmission mounting holes, and it's using the stock Revo input shaft.
