11.06.2007, 12:49 PM
To help reduce tyre ballooning, you can stick some duct tape around the inside of the tire- you have to remove them, turn them inside out, run the tape around then a couple times, then turn them back to normal and glue them onto the rims- helps alot or so I hear.
