MetalMan
MetalMan's Avatar
11.09.2007, 02:06 AM
Originally Posted by cart213 View Post
It looks good. My old MT2 had the same layout with 4s2p emoli cells.
Metalman, do you have the 18SS diffs on your MT2? Those diffs are a lot stronger than the stock MT2 ones. I never had any problems with my 18SS diffs with a 9L on the above-mentioned emolis.
Yep, I have the full 18SS kit. I have no problem skipping the diffs, but if I take it easy they won't skip. The gears look perfect, and there are no metal shavings in the diff case. I did just receive some aluminum diff housings for the front and rear though...
Just for comparison (to cart213's MT2 and tashpop's LS10), my MT2 is running a Feigao 9L and 4s2p A123 through a MM.
