Originally Posted by chumanji
What do you guys think about the Tekno conversion kit. Opinions pls.
Are there any big difference between the 8xl and 9xl motor?
If I use the Tekno kit, do I need to change any gear ratio or use the stock clutch bell.
Do I need to lock the 2nd speed? What other mods do I need to do?
You can stick with the same gearing you used on the Revo with the same trans. That is what it was designed for. However with the extra power/torque of BL you may want to gear it a little taller. Yes you can and will be using the stock clutchbell. No you do not need to lock 2nd if you want to have a 2 speed trans. I have the Tekno kit and think it is great. I am also going to be using the stock Revo 2 speed trans. I do however have the FOC (forward only control) installed in it. I am also going to be running 16/36 gearing to start and then try a 18/36.
