Probably your hinge pins. Check to see if they're warped or bent. Then check your bulkhead for the same thing. If it's not your pivot balls, then this should be the culprit. It's not your shocks, I'll tell you that.
Also, check the bearings on your rockers. Make sure they spin freely and don't need to be replaced.
