MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
12.19.2007, 04:52 PM
That is a known fault with the plastic caps - They flex too much and can break the top of the shick off - You can rebuild them with the aliminium caps and plumbers tape which stops most issues.
This pede has Traxxas Aliminium big Bores all round so the only issue I get is bent shafts...
I popped in some stiffer blue springs in the back last night too after the photo was taken...
Thanks. I might give those a try. And that idea with the fuel tubing would probably work too. I doubt it's worth fixing the stock ones now as they have popped so many times the threads not looking too good.
