Got pics? I wonder if the width of the new mounting points is okay, and it just requires 4 new holes drilled onto the chassis (mount it ontop, rather than underslung).....
Ok Neil, here ya go partner.
Check out the pics. You can see the 4 tranny mount bolt there on the underside of the chassis. Bolts are 41mm x 52mm center to center.
