fan mounting for mm esc
fan mounting for mm esc - 01.04.2008, 11:33 PM
does anyone have any good ideas to mount the fan above the esc so it STAYS PUT?
01.04.2008, 11:35 PM
m3 screws directly between the fins on the heatsink. Go slowly and the screw will cut its own threads. Never had a fan fall off when mounted that way. It also helps to space the fan off the heatsink 1/4" or so, helps with air flow.
01.04.2008, 11:49 PM
what's the best way to space off the fan?
ssspconcepts
ssspconcepts's Avatar
01.04.2008, 11:52 PM
Never tried it, but it seems that rubber fuel tubing cut to size would work good as spacers.
BTW...the 25mm novak fans fit perfect on the MM.
01.04.2008, 11:55 PM
thanks for the tips
