One note!!! With the mamba maxx on 12 cells you should disconnect the red wire on the ESC plug to the Rx and use a receiver battery or UBEC. 12 cells on the mamba maxx will likely overheat the built in bec. I would do this before running it.
to make it...
or break it...
