DrKnow65
DrKnow65's Avatar
01.05.2008, 09:19 PM
@ GriffenRU, I've seen two different post's on people having problems running the MM with a reciever pack. I have seen the same thing in testing different configurations on my stuff.
I've just been thinking it's a difference between the voltage of the reciever pack/radio and the internal bec voltage of the MM. Say a 1.5ms signal at 6.0volts and a MM brain board voltage of 5.
Is there a way to disconnect the internal BEC in the mamba max and back feed the circuit? I.E. the ubec/reciever pack powering the brain board?
