Yeah, the ESC is most probsbly toast. Before you go get another ESC, I would try to see if there was anything wrong that caused it. Maybe the motor leads were shorted? Maybe the motor is bad? What voltage were you running? If over 2s or 7 cells, were you using an external BEC or the internal ESC BEC?
