GO-RIDE.com
01.31.2008, 08:33 PM
I have the RCM Ext Chassis, so I don't really plan on going back to mech brakes. The electric brakes are really powerfull with my motor esc combo. It will actually lift the rear wheels off the ground. The track I drive is very high bite, so you don't need brakes too often, and most of the 10th scale 4X4 buggys run one-ways. Of course they also run a center slipper instead of a center diff, so that may make a difference.
I guess I could remove the front drive shaft for a quick test to see if the rear would be enough brakes?
E-8ight - Tekin RX8 2000kv/4S
