02.04.2008, 11:18 AM
The only way to retain the power and lower the temps is to go with an xl motor, or a more effecient motor. The 8l is getting hot from spinning too fast. A 10l would be better as it spins less than 40k rpm. Akk I can say is to go it a try. Ohterwise go to a hacker motor, a 10l from them should produce as much power as the 8l feigao and run cooler too.
My emaxx was completely stock save for the removal of the front diff and driveshafts, and a set of cvds in the rear. It has the gmaxx single speed too.
