sikeston34m
sikeston34m's Avatar
02.10.2008, 11:23 PM
You need to pass them up, too heavy and not worth the cost. Go with the 8000 truerc packs, much better value and will fit better as they are smaller in size. I had a few 10000 packs and was not impressed at all.
I have a pair of 10,000mah packs that are 45mm wide X 135mm long. They are about 35mm thick. Each one weighs 17 oz. Pretty heavy.
The pair would run my Revo for almost an hour straight of hard running. But the extra weight is hard on the drivetrain and does tend to slow it down somewhat.
The ones I have do put out really good power. 100amps continous with 150 amp burst. These aren't lacking on power.
I've been thinking maybe the best use for these would be in a boat.
