marzac2
marzac2's Avatar
02.18.2008, 10:22 PM
Can I help with your MGM problems? Are you still not able to program it?
Let me guess.. You have a Futaba transmitter.
Switch it from HRS mode to PPM mode. It will only recognize PPM right now. (in a few weeks MGM will offer an updated program to enable the controller to work fine with both PPM and HRS).
Also you will need to change the servo direction for the throttle servo (via transmitter settings). Futaba has their servo directions reversed from what other manufacturers have.
After this, you should be able to set it up.
After you program the controller for the first time, continue on and follow the "automatic tuning" section in the manual. It will finish off most of the "tuning" you need to do with this controller.
Hope this helps!
