skellyo
skellyo's Avatar
03.07.2008, 01:19 PM
Have to remember that the velineon can only run 50k rpms because of the bigger rotor.
BS...there's already been folks running them on 4S.
http://www.ultimaterc.com/forums/showthread.php?t=87772
jhautz
jhautz's Avatar
03.07.2008, 01:28 PM
Isnt the vleinon 3100kv. 3100*14.8(4s) = 45880rpm
45880 < 50000
EDIT: OK Just looked it up. Its 35000k.... Still just a smidge over the 50000. 51K and change.
I'll just shut up now.
to make it...
or break it...
Silent...But Deadly
snellemin
2 KiloWatt RACER
snellemin's Avatar
03.07.2008, 01:36 PM
That is Rotation per minute. Speed runs don't last a minute and neither do dragraces. Bashing is mostly 20 second blips and then brake.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
03.07.2008, 01:50 PM
On 3s the velineon motor will be fine. It is about the same size as a s can feigao. Similar to a 10s, if memory serves me correctly. I ran a 12s feigao in a stampede on 3s lipo thru a mm and it had tons of power, even geared for 50mph. I have had more success with the feiao motors, than the mm motors. And the vxl rustler I had ran too hot for my liking, but I never played with the gearing.
cart213
cart213's Avatar
03.07.2008, 04:27 PM
Rotation per minute (rpm) refers to the rate of rotation, not the duration of rotation. The amount of time you run the motor is not a factor with rpm.
